Loosing Alternator??????
Scot
Howell, MI
Ford Logic...
If the single alternator is going to be an option why would they make it a 110a? Wouldn't it be just as easy to engineer for the 140 that comes with some duals? I don't think that would take away from their dual sales. I'm having some electrical issues and my testing shows: at idle with lights, heat, brake and cargo trailer hooked up my voltage dropped to 12.1 @ idle. With the RPM @ 1500 it goes up to 12.5. I don't know if that's an acceptable range but the dealer says the charging sythem is fine.
Northeast Texas
wow another newbie
welcome to the place to be
yep even under load i think 12.5 is marginal at best, but lets see what the electrical experts have to say
an unloaded electr should run 1200-1500 rpm in the range of 13.8 ish to 14.5 ish i f i remember correctly
its been awhile
6.0L OHV Power Stroke Turbo Diesel V-8 2.79:1 Super Duty F-Series
6.0L OHV Power Stroke Turbo Diesel V-8 2.49:1 E-Series
6.8L 2V SOHC Triton V-10 2.72:1 E-Series
6.8L 3V SOHC Triton V-10 2.72:1 F-53 Motorhome Chassis
https://www.fleet.ford.com/truckbbas/non-html/2006/vs_pdf/trkelec_06.pdf
the above link has the power curve for teh alt. in amps versus rpms but does not break it down to voltage
whatabudro
Launched
My truck's alternator supplied a whopping 11.6v after 30 seconds of running after starting it this afternoon. I hit charge protect on the AIC to read it w/o the emergency brake engaged. I checked it again at the first stop light on the way home. That would be 2 minutes and 3/4 mile. 14.7 then. Bryan
I bet we could talk Bryan into re-engineering the stock alternators to higher amperage output levels;)
Northeast Texas
i will donate a 6 pack of his favorite beverage to the cause :D
Kleetus
Butler PA
That's kinda strange seeing all those ranges for trucks to '06... I just bought an '06, and got dual alternators, and with the plow package. In theory, I should have 2 130 amp units, but with the plow package, I would have ended up with a single 140 amp. Sales literature shows 130a, or 140a as the only options... jmight need to read a few part numbers to figure out what is what. I'll let you know when they deliver the truck.
