Looking for F350 rear blocks
paulkeith
Da A
where's the best (read: cheapest) place to pick up a set of 350 rear blocks and ubolts?
Paul
paulkeith
Da A
wrecking yards full of 4x4 f350s aren't really common down here....
has anyone purchased them from a stealer or internet shop?
Paul
Whata250
Whata250
heath, TX
I bought mine on line...but will have to look to see where
I think it was $60 for blocks and ubolts. You will need to know if your overloads are above the springs are below when ordering.
paulkeith
Da A
yeah, that's fine. see if you can find where, i appreciate it.
paul
GOEGLEINBROS
Wright Cicty, MO
If you do the leveling kit and put F350 blocks in the back. Do you have to do anything to the carrier bearing? I'm not to sure. I think the 4x4 shop was just trying to sell me thier $95 per labor and new parts.
bigtrxs
I just sold a pair of 2" blocks and u-bolts on ebay! I had them on my 03 f350 but i removed them after i put air bags.If your going with a 2" you dont have to do nothing to your truck.Oem shocks will still work and you dont have to mess with the carrier bearing eather.I bought my block at the dealer but im sure you can find them at ajunk yard....::)
JimmyDee
God Bless America
Western Michigan
I am fairly sure that the shocks will bottom out before hitting the shock stops. They are a tad bit long if you go from the 4" to the 2" blocks. I think you will need the Motorcraft CK05TIC which are 1 3/4" shorter. I installed Rancho's and they didn't have, at that time, a shock that would be the proper fit for the 2" blocks. I spent many hours on the line with the Rancho customer service dept. I ended up retrofitting the axle shock brackets to give me an extra inch and used the longer shocks.
Don't take my word for it, do some careful measuring and I think you will find what I'm saying to be true.
Jim
Brad1103
