Little oil leak...
rickh
Biodiesel Rules!
Bellevue Nerbaska
RoReRi said:
On my previous post I lied...:D I really didn't taste it, ;)
RoReRi
I taste every batch of Biodiesel I make! Nothing wrong with that!
Check the HPOP lines that go from the pump to the heads You have to clean around them and then watch em while engine is running.
The orings can seep. The more rpms the more oil.
Rick H...
RoReRi
Verona, NC
UPDATE....
Found the "leak" NOT.... what I mean its not the kind of leak I was looking for. It was shoddy work from a guy I let work on my truck. He had not connected the drain hose to the fuel/filter canister AND on top of that I had bumped the little yellow lever or something last time when I was fooling around up there.
Thanks for all the help, I now know that everything else is fine.
Confidence level up one notch.
RoReRi:thanks
Brad1103
