LEVELING 2008 F250 4x4
socal14
simi valley calif
installing a readylift spring spacer changes the panhard bar loc makes it to short so you have to shift the axle houseing to make it fit then the truck will pull the the left took it ford they said can not be fixed so i called readylift and bought a panhard bracket that changes the loc worked great 2008 f250 4x4
Rusty74
Highlands Ranch, Colorado
That is intresting SOCAL14 I installed the truxx lift on the front took it in to Ford and had the alinement done and it is good w/o carrier bearing shims or panhard bracket. 350's must be fine.
NIFTY250, all you should need is new front leafs, shocks and carrier bearing shim, about 1/4" per 1" lift in the front.
trickyricky23r
