Aug 25, 2009 #1 RON.B54 Full Access Member Joined Feb 11, 2008 Messages 58 Reaction score 0 Location CLOVIS,NM What would cause the left head light to be dimmer than the right. Is it an easy fix like a bad ground?
Aug 25, 2009 #2 D Dogman Full Access Member Joined Nov 19, 2007 Messages 1,789 Reaction score 2 Location tampa,FL Would be a good start. I put in the head light wire upgrade was EZ took 5 min.
Aug 25, 2009 #3 AK Rover Full Access Member Joined Jul 26, 2009 Messages 200 Reaction score 1 Location Kenai, Alaska Check your grounds first and also check to make sure the contacts in the plug are clean
