hello again, i had a leaking pinion seal on my 06 f350 so i took the driveline off and pulled the bolt up hub out and put a new seal in, the thing i am not sure about is when i pulled the hub the pinion gear became very loose, and when i put the nut back on i feel like i am not doing something correctly, i have heard maybe you have to crush something??? I used an impact to put the nut back on the pinion as it goes on very hard and doing it by hand does not seem feasable. Can anyone tell me about this procedure, maybe i should take it to a shop and have them do the repair??
Thanks in advance for any advice, i tried searching the forum for something already posted but i kept getting nothing back so maybe i am not searching correctly.
