vinceismyhero
I have an 03 FX4 6.0 supercab with terrible low end power after start up. I have had this problem for a while and can't seem to fix it. Had the EGR replaced and what i think was a reflash (something to do with cold starts) from the dealer. It seemed to run better right after i had that done but now it is going back to the way it was before. After startup I can stomp on the throttle and the rpm's SLOWLY rise. For example, leaving my neighborhood today I pulled out onto the main road and I almost got run over because I could not get up to speed fast enough. Once I get up to speed I have plenty of power. Same goes for towing my boat. Pulling it out of the lake is a dog but towing it home is no problem. It's almost the engine is cold but its 100 degrees here right now so I know thats not it. What do you guys think? Will unplugging the EGR help? Any suggestions on what the problem is and how to fix it without just adding a chip/tuner?
