Lack of power
vinceismyhero
Tx
I have an 03 FX4 6.0 supercab with terrible low end power after start up. I have had this problem for a while and can't seem to fix it. Had the EGR replaced and what i think was a reflash (something to do with cold starts) from the dealer. It seemed to run better right after i had that done but now it is going back to the way it was before. After startup I can stomp on the throttle and the rpm's SLOWLY rise. For example, leaving my neighborhood today I pulled out onto the main road and I almost got run over because I could not get up to speed fast enough. Once I get up to speed I have plenty of power. Same goes for towing my boat. Pulling it out of the lake is a dog but towing it home is no problem. It's almost the engine is cold but its 100 degrees here right now so I know thats not it. What do you guys think? Will unplugging the EGR help? Any suggestions on what the problem is and how to fix it without just adding a chip/tuner?
lvtitan
prototype
$in city
try plugging the truck in at night, even though it's not that cold out..
sounds exactly what mine would do when the injectors were shot...
the new ones made a world of difference
vinceismyhero
Tx
I've tried plugging it in when it was colder. No real difference. How much does new injectors cost? Is there some way I can try to clean the injectors with something like Seafoam?
F350DRW1
Waylon Fan
N.J.
Check ICP sensor and pigtail going to it. Also IPR. Need to run codes to see whats up. Adding a tuner won't do much if truck isn't mechanically sound. I'd unplug the egr if truck was running right or not.
Coastal6.0
New Orleans La.
What help does unpluging the EGR offer? More perf. or it'll never break? Not being a smart ass, just wondering.
vinceismyhero
Tx
ICP has been replaced less than a year ago. Not sure about the IPR. How do I go about unplugging the EGR? Once it's unplugged should I notice any difference in performance?
F350DRW1
Waylon Fan
N.J.
Unplug egr? Shut key off, remove plug. Start, drive, enjoy. Do it, then you tell me how it runs. :sly
Coastal6.0
New Orleans La.
Where is the EGR on the 6.0. Just changed one today on a 4.6 F150 and it was next to the throttlebody. I guess i'm just not seeing it.
desert50eagle
Palos Hills/Illinois
Try right next to the oil filter(7 oclock if your looking at the top of the filter) It has the wiring plug/harness sticking out of the top. I unplugged mine and had no light come on....plus she runs way better!!!!!!!
BLUKAS
