Killed my truck
bonestroker
stroke it if you got it
In the field
I hap a prob like that about a yr ago try and find the wires going to the pcm under the dash to the fuse box it coast me about $900 to have the meck plug the wires ALL the way in ( and hes the one that unpluged it ) -mad
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Called DpTuner today and will have a PCM on friday burned to DAC3 instead of the XPC4 cackle fix one that I toasted. My chip is burnt to DAC3 so it will at least be a match now. I'm sending Jody my chip to have him check it out to see if I hurt that also. Diane and Jody are great people to deal with. I did try unhooking the batterys but no go.
f100cleveland
Southern Minnesota
My truck is up and running again thanks to all here that ageed that the PCM was bad. Nice to know there is a place that you can get info in a hurry when you need help.
jopes
Wyoming
I know with the older tuner I have for my bronco's EFI it says in bold print "do not remove while key is on or engine is running" supposedly it will damage the tuner and ECM. But who knows on the new stuff. Just to be sure I used a excessive amount of Duct tape to make sure my tuner does not fall out of the ECM.
