Keyless entry
hdjeff
Medina, Ohio
I'm pretty sure my truck came with keyless entry but i dont have a remote. How can i find out??
Gubni
Newbie
Northeast TN
I have two that I don't use. $20 sound fair?
Edit: -- not for sale any more --
hdjeff
Medina, Ohio
thats sound good, but how do i know that i actually have the option of keyless entry. i dont want to buy remotes and not have them work.
Gubni
Newbie
Northeast TN
Hehe, that's why I have them for sale. They came with my truck, but the PO said he never could get them to work. I don't think mine has that option. The controller if it has one is left of the guages, but that's the only info I could find and that's not enough for me to go by. I also was unable to find a program sequence for a 94 to 97 truck. The 99 up in 8 turns on and off, then leave it on and hit the lock button.
Gubni
Newbie
Northeast TN
Just found this on another site. I'm going to go try it on mine now.
"From the Ford service CD:
Programming, Electronic Door Lock Control Processor
Note:
The remote entry features will not function when the key is in the RUN or ACCESSORY position.
To unlock the driver's door, press the UNLOCK button on the transmitter (which is programmed into the remote entry receiver module) once. This will also disarm the anti-theft system, if equipped.
To unlock all doors, press the UNLOCK button on the transmitter twice. The second depression must be within five seconds of the first UNLOCK depression.
If more than five seconds have elapsed since the first depression of the UNLOCK button, pressing the UNLOCK button again will only unlock the driver's door.
To turn on interior lamps (13776), press either UNLOCK or PANIC.
To lock all doors, press the LOCK button on the transmitter once.
To confirm that doors have locked, press LOCK button again, within five seconds of the first depression. This will beep the horn (13832), flash the parking lamps and lock all doors again.
To activate the personal security alarm, press the red PANIC button. The horn will beep and parking lamps (13201) will flash for a maximum of two minutes, forty-five seconds.
To deactivate the personal security alarm, press the red PANIC button again or turn the ignition switch (11572) ON.
Note:
The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The remote entry receiver module can store up to four transmitters in memory.
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
1. Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
2. Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
3. Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
4. Key off. All doors should lock then unlock.
5. Check operation.
hdjeff
Medina, Ohio
so is the controller box located under the dash left f the cluster or inside the dash?
Gubni
Newbie
Northeast TN
Yes, it's in that ballpark. I haven't found any exacts yet. I'm working google hard though.
Gubni
Newbie
Northeast TN
The proper remote for our older trucks will have the following info on the back. My remotes have this same info on it also, so should work if I can find the module.
FCC ID: GQ43VT4T
DOC:1470 K763
TRW Inc 3165189
Gubni
Newbie
Northeast TN
Here's a link to a pic.
getfile.php
Lin50D582
