3 temprature capable gauge, useing 1, 100 to 230 degree temp guage. Engine, Trans and Diff temps.
Thought I'd pass it on.
Used 2 SPDT micro switches (Radio Shack). Mounted one switch down on the Dash, left side of the steering column.
Hooked the Trans leed to it's upper pole.
Diff leed to the lower pole.
Center wire to the other switches upper pole.
Mounted the second switch to the upper left of the Temp gauge, on it's "A" pillar pod.
Hooked the engine temp leed to the lower pole.
Center pole to the gauge.
CONFUSED YET ???
Here's what I git:
With the >Pod< switch in the up position: Engine Temp. (where I normaly keep it)
With the >Pod< switch in the down position: by flipping the Dash mounted switch, I git Trans temp (up), or Diff temp (down).
Hope I made sense here.
The REAL BIG, REAL temprature Indication is: THE ENGINE TEMP !!!!
For those that don't have a REAL engine temp gauge ? If you tow or work yer PSD ? I'd say: Git one.
I'v seen 220 degrees (pul'n a 7% grade)..... That FORD idiot gauge just stayed.... right there, in the middle of "Normal"... Makes me think: when you hear the LOUD Bang.... it's prolly to late. If yer relying on that thing.
Knowing Tranny & Diff temps are a "Warm'n Fuzzy" Too
JOE
CONFUSED YET ???
Here's what I git:
JOE
