Just over Half Throttle
Weweld
Fillmore Ca.
Have you had the speedo go back to zero and start climing again.
Does it on every pass down the track.
It's really cool to watch.
GENE
HTRDDSL
HTRDDSL
St. Albert, Alberta
I've never seen that Gene but then again I don't stay at that speed for long because of the tires.
I didn't know it could do that but I'd love to see it.:D
HTRDDSL, So you are running all most 160 Kh, that would be about 100 MPH down here and I have been told the trucks down south of you cut out at around 105MPH. Does your cut out? I run my 06 up to 90 MPH the other day just to see if it would do it. It does it so fast.
HTRDDSL
HTRDDSL
St. Albert, Alberta
I have the Superchips 3 setting tuner installed. It gives you the option of bypassing the speed cutoff. Actually the needle is just down past 160. At the time I took the photo I didn't realize the speedometer is electronic or I would have gone faster.:D
TacoCat
