I have had my EGT gauge for two years and now the gauge is just bouncing around now and I'm going nuts with it. The grounds are good, can the prob. go bad? It's a autometer. Any other ideas?
KKD- the boost gauge is pneumatic. i would look for a pinch in the line from the tap all the way to the gauge. check the fitting too, it could be loose and leaking.
Thanks DP, thats what I figured, especially since it was not bouncing at idle. I am just going to replace the cheap plastic tubing that comes with it. I will probably make my own out of Vacuum hose.
