dpantazis
#12
dogman- you sure the starter is good? could it be stuck and drawing too much power?
Checked the starter it good, A/C works, did pull the HFCM relay.so we will see what happens.....
Just to clarify.... "fuel heater relay"???
Check and make sure your a/c compresor is not seiesed. disconect your serpintine belt then fire it up see if that works for ya. If so install new compresor problem solved!!
