Jhnybravo
Inverter - go big!
I have an 1800 Watt Xantrex Inverter setting on the floor hump in front of the console. I plan to eventually build another console out of Starboard (marine grade plastic) to keep it up off the carpet and allow it to breath more. If you block the fans on the inverter and run decent loads, it will eventually burn it up. I oversized mine so I can run anything...skill saw, drills, you name it.
-Jhnybravo
'05 F250
(currently at the body shop being repaired from tennis ball-sized hail)
-Jhnybravo
'05 F250
