Inverter problem
jjuday30
US
I just got my 2022 F250 Platinum a few days ago. Today we took our first trip when my laptop was low on power. I plugged it in. The light was solid yellow, and it started to blink yellow, and it would not charge. I turned the truck off to reset, and the same thing happened. It says 400w max on the truck. My laptop charger says it's 300w.
Any ideas of how to fix this?
mreaz93
Phoenix Arizona
Wondering what you devised?-lol
I carry my air compressor in the back covered with a Bak Flip Cover.....sooo I've got my 38' TT hiked up and I needed to check the trailer tires. I get this BRILLIANT idea to open the rear window slider and run an extension cord into the cab. Flip on the compressor ....and well too bad that's not gonna work[emoji848]
Truck was running , but compressor wouldn't fire up> I too have 400w Inverter.
I suppose adding or replacing with a larger unit?
Also maybe I will try the compressor again with a shorter amp correct size cord?
Sent from my SM-G965U1 using Tapatalk
