intro
ando6769
east hampton,ny,11937
yes exactly well greased regularly no signs of rust yes replacing all with moog like any other suspension or steering component problem i have come across just never had a tie rod snap pretty heavy duty clueless i will say while driving hitting a bump in the road or som ething hear some milde clunking checked it out many times changed upper and lower ball joints hopefully this will have something to do with it.i want to change my hubs need bearings soon plus oter hub switch auto/lock is chewed up a bit asny sugestions on what hub to use?thanks for all your help
yes, exactly, well greased regularly, no signs of rust. Yes, replacing all with moog like any other suspension or steering component problem i have come across, just never had a tie rod snap pretty heavy duty. Clueless, i will say while driving hitting a bump in the road or something, hear some milde clunking, checked it out many times changed upper and lower ball joints, hopefully this will have something to do with it.i want to change my hubs, need bearings soon, plus oter hub switch auto/lock is chewed up a bit, asny sugestions on what hub to use? thanks for all your help
I added a 'lil Punctuation for ya ;):lmao
Sounds like a basic 4X4 Front End rebuild, is in order ?
ando6769
well thanks guys for your comments always good to hear other opinions as to my truck i pretty much rebuilt front end with all heavy duty moog 4x4 problem solver componets both side upper and lower moog ball joints MOOG pitman arm outer r tie rod OUTER left inner left tie end from pit arm to adjust sleeve new moog drag link including adjust sleeves on link and rod new moog steering damper everything new had a ball doing it to this weekend coming changing auto/lock hubs and bearing and new tires this ole girl has treated me right for 10 years i owe her some tlc work horse never left me and pretty much never let me down has almost 200k on her 7.3 diesel and runs like a charm pulled plenty of chevy,gmc dodge outta snow banks off the beach once a gov. bailout neein chevy with 34' 5th wheel stuck on gin beach in montauk purrede her righ off Ford Power Baby other than regular maintenance issues its long overdue for a nice long scatch under the belly each weekend.i feel a little play in whats part called? axle drive has like ujoints/diff at each front wheel? not the ujoint itself could be bearing i will see but got some new love for my old truck have to shoot some b4 and afters.any advice welcome also been awhile since school but i dont think there should be play there or movement or what even makes them tight but i will.
ando6769
well thanks guys for your comments always good to hear other opinions as to my truck i pretty much rebuilt front end with all heavy duty moog 4x4 problem solver componets both side upper and lower moog ball joints MOOG pitman arm outer r tie rod OUTER left inner left tie end from pit arm to adjust sleeve new moog drag link including adjust sleeves on link and rod new moog steering damper everything new had a ball doing it to this weekend coming changing auto/lock hubs and bearing and new tires this ole girl has treated me right for 10 years i owe her some tlc work horse never left me and pretty much never let me down has almost 200k on her 7.3 diesel and runs like a charm pulled plenty of chevy,gmc dodge outta snow banks off the beach once a gov. bailout neein chevy with 34' 5th wheel stuck on gin beach in montauk purrede her righ off Ford Power Baby other than regular maintenance issues its long overdue for a nice long scatch under the belly each weekend.i feel a little play in whats part called? axle drive has like ujoints/diff at each front wheel? not the ujoint itself could be bearing i will see but got some new love for my old truck have to shoot some b4 and afters.any advice welcome also been awhile since school but i dont think there should be play there or movement or what even makes them tight but i will.thanks again for all your replies and advice......LOVE EM FORDS
:D:D:clap::clap::sweet
Sincerely Robbie 2002 F250 SD Lariat crew cab 7.3 PSD
gotogelsuper8461
