Bolt
Not quite in the same ballpark as just moving some switches around and re-wiring. Sure, lets whack a hole in the floor board, swap out a transfer case, and hook everthing back up!
I'm digging up an old post here, sorry. Nice work, I have an air pressure and voltage gauge in my quad-pillar, never got the air gauge hooked up yet, but the voltage meter is quite handy.
Have you ever gotten any farther on the ESOF mod? Were you planning on moving the factory switch or using Carling rockers to do the work of the old dial switch? I've thought about doing so, but feel the Carlings might be too easily bumped when reaching across the dash. Just wondering if you ever did anything on that front yet.
that looks good stephen... cept not what are you gunna do with the empty space that you have where it sat on the old dash?
Today 09:47 AM
Bolt Looks sharp. Is the lever switch for your air horns? I'm sure that's been discussed before.
