Interesting Reading
no-red 6 0
Senioritis
southmetro MN
Please go ahead and read, then i would like any and all feedback. Pretty upset at the current situation. Frustrated is more like it. Not sure what to do!!
Hi,
Here's the rest of it.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 0 6J09 011401 F85Z 1521990 BA L06 42 4
AWS Claim Key: 1796424 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2003 Doc #:153012B
Cust Comments: LEFT FRONT DOOR KEY WONT TURN IN CYLINDER. RIGHT SIDE OK
Tech Comments: REPLACE LEFT DOOR LOCK CYLINDER. OSL TO ASSEMBLE AND SET PINS TO KEY
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 0 6H06 011103 3C3Z 7821537 AA G07 41 5
AWS Claim Key: 2229605 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2003 Doc #:153579A
Cust Comments: DR SIDE WINDOW SLOW CATCHING ON SOMETHING
Tech Comments: LUBE TRACK...NO HELP. R&R DOOR TRIM PANEL AND REPLACE WINDOW RUN CHANNEL.
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 0 5B04 050306 F81Z 1K106 AA P82 12 5
AWS Claim Key: 2229606 Trx Code: 1 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2003 Doc #:153579B
Cust Comments: TIGHT TURNS CAUSES A BUCK SURGE
Tech Comments: RUN BCE DIAG...NO CODES IN PINPOINT TEST. PERFORM MODIFICATION TO KEYWAYS AND REPLACE O RINGS AS PERTSB 03 14 3
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 0 1D01 030008 3C3Z 6701 AA L65 D8 5
AWS Claim Key: 2229607 Trx Code: 1 Labor Hrs: 5
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2003 Doc #:153579C
Cust Comments: REAR AREA OF ENGINE HAS OIL LEAK
Tech Comments: CHECK LEAK WITH DYE LIGHT. REAR MAIN SEAL FAILURE.R&R TRANSMISSION AND REPLACE SEAL. REASSEMBLE AND RECHECK...OK
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 2 2G05 031405 * RECAL * D13 82 2135
AWS Claim Key: 2965344 Trx Code: 1 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2003 Doc #:155432D
Cust Comments: COLD START SMOKES AND SURGES
Tech Comments: RUN DIESEL PERFORMANCE DIAGNOSIS, REPROGRAM FICM, TCM, PCM. ROAD TEST FOR FUEL ECON TEST 19MPG. RETEST OK
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 2 2G04 000615 * DIAG * D13 82 2735
AWS Claim Key: 3190594 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2003 Doc #:155605A
Cust Comments: SMOKES BADLY AND SURGES
Tech Comments: RERUN DIESEL PERFORMANCE TESTS. NO CODES. ALL SYSTEMS IN SPEC. RECOMMEND CHECKING FUEL SOURCE FOR HIGHER GRADE DIESEL FUEL
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 2 5C01 050101 * 4800 * N18 07 2735
AWS Claim Key: 3150765 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2003 Doc #:155605B
Cust Comments: CLUNK NOISE IN FRONT
Tech Comments: ROAD TEST, RAISE ON HOIST. CHECK DRIVELINE ANGLE. R&R REAR DRIVE SHAFT AND SHIM CENTER SUPPORT BEARING ASY
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 2 7K11 130101 3C3Z 10849 HA L69 42 2735
AWS Claim Key: 3150766 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2003 Doc #:155605C
Cust Comments: FUEL GAUGE INOP
Tech Comments: RUN FUEL SYSTEM TEST, REPLACE HEC MODULE
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 2 7D07 1702XX C2AZ 13466 C L26 46 2735
AWS Claim Key: 3150767 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2003 Doc #:155605D
Cust Comments: LEFT PARK LAMP BULB BURNT OUT
Tech Comments: REPLACED BULB
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 13 2G04 000615 * NPF * D35 82 19136
AWS Claim Key: 7655339 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2004 Doc #:163668C
Cust Comments: POOR FUEL ECONOMY SEE LIST ON CENTER CONSOLE
Tech Comments: ROAD TEST TO MONITOR MGP PID, BOOST 24 PSI AT WOT...NORMAL AS PER SSM 17691. 30 MPG AT 56 MPH FLAT SURFACE.
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 13 2G05 031405 * RECAL * D13 82 19136
AWS Claim Key: 7638637 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2004 Doc #:163668D
Cust Comments: RUNS ROUGH
Tech Comments: RUN WDS DIAG, DCL DISPLAY PASS. ROAD TEST TO MONITOR PIDS. REPROGRAM COMPUTERS TO LATEST CALIBRATIONLEVEL. OK AT THIS TIME
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 17 2G04 000615 * NPF * D35 82 24040
AWS Claim Key: 9511428 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09501 - * Name: BOYER TRUCKS SO. ST. PAUL Ph: 651-4501500 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-JAN-2005 Doc #:515190B
Cust Comments: REPAIR FOR POOR FUEL ECONOMY,GETTING APPROX:10 HWY
Tech Comments: 9080 CHECKED FOR ANY TSBS OR SSMS FOR POOR MI LEAGE.OASIS CODE#111 244 598....ALSO,ADVISED CU STOMER ON WHERE HE IS FILLING UP WITH DIESEL,AL SO,QUALITY OF MOTOROIL BEING USED..SHOULD BE US ING FORD OIL
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 17 5G88 000615 * NPF * N50 82 24040
AWS Claim Key: 9511429 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09501 - * Name: BOYER TRUCKS SO. ST. PAUL Ph: 651-4501500 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-JAN-2005 Doc #:515190C
Cust Comments: REPAIR FOR FRONT END MAKING A CLICKING TYPE NOISE WHEN WHEEL IS TURNED AND ACCEL:FROM A STOP
Tech Comments: TEST DROVE, CHECKED OVER FRONT END, NPF. CANT DUPLICATE CUST. CONCERN. CHECKED FOR ANY TSBS OR SSMS PERTAINING TO NO ISE IN FRT END,WHEN TURNING SLIGHLT AND ACCEL:, NONE FOUND:OASIS CODE# 111 235 167
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 17 2H01 030008 3C3Z 6K682 AARM D42 42 24040
AWS Claim Key: 9511430 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 09501 - * Name: BOYER TRUCKS SO. ST. PAUL Ph: 651-4501500 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:28-JAN-2005 Doc #:515190D
Cust Comments: REPAIR FOR INTERMITTENT POWER LOSS,WHERE TURBO DIDNT ENGAGE,AND THEN RPMS WENT UP TO AROUND 3500
Tech Comments: TEST DROVE, HOOKED UP TO WDS, TESTED FOR ALL CMDTCS HAS 3 CODES, B1483, P0500 AND P2263 CHECKED OASIS. CHECKED OVER ENG. REMOVED THE AIR CLEANER AND PIPING, CHECKED OVER ENG WIRING FOUND OIL LEAKING THROUGH THE #8 INJECTOR WIRES AT CONNECTOR 1313. REPLACED #8 INJECTOR. REPLACED THE VGT CONTROL VALVE AS PER SSM 18069 REPROGRAMMED THE PCM TO THE LATEST CALIBRATION. REASSEMBLED
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 27 2G05 031405 * RECALEM * D50 42 38236
AWS Claim Key: 12567750 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09179 - * Name: INVER GROVE FORD Ph: 651-4512201 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2005 Doc #:41595303
Cust Comments: CUSTOMER STATES THAT THE VEHICLE SMOKES BADLY WHEN COLD START AND SMELLS BAD PLEASE CHECK
Tech Comments: PERFORMED KOEO, KOER, NO CODES PERFORMED PCM REPROGRAMM STARTED AFTER COOL DOWN TIME NO EXCESSIVE SMOKE NOTICED
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 32 1D01 03***X 3C3Z 6701 AA L65 D8 42845
AWS Claim Key: 13758943 Trx Code: E72 Labor Hrs: 9.6
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:177894A
Cust Comments: CHECK FOR OIL LEAK
Tech Comments: REAR MAIN SEAL LEAKING, R&R TRANSMISSION, REPLACESEAL, EXHAUST MAINFOLD GASKETS LEAKING, REPLACED, REPLACED CMP SEAL, AND LEFT GLOW PLUG HARNESS.
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 32 * * * * * * * 42845
AWS Claim Key: 13758944 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:177894C
Cust Comments: CHECK RECALL ON EGR
Tech Comments: COMPLETED FSA
AWS Claim Key: 13758945 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:177894D
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE REPLACE L
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 32 2G05 031405 * RECAL * D35 04 42845
AWS Claim Key: 13758946 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09212 - * Name: HASTINGS AUTOMOTIVE, INC. Ph: 651-4374030 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:177894E
Cust Comments: CHECK FUEL ECONOMY
Tech Comments: ROAD TEST USING WDS TO MONITOR FUEL ECONOMY PIDS. 17.9 MPG AGAINST WIND, 22.7 WITH WIND AT 55 MPH. REPROGRAM PCM FOR TIRE SIZE AS PER FSE.
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 33 2H01 030008 3C3Z 6K682 BARM D36 41 43172
AWS Claim Key: 13775920 Trx Code: S07 Labor Hrs: 13
Dlr Cd-Sub Cd: 09217 - * Name: APPLE VALLEY FORD LINCOLN MERCURY Ph: 952-4315900 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:53357701
Cust Comments: CHECK FOR NO POWER AND SMOKES ON START UP
Tech Comments: CC42 9E527 6K682 9F452 9T517 9F838 DIESEL PERFORMANCE SHEET, KOEO P0401,P2263,CONT SAME,KOER P0401,POWER BALANCE PER TSB 06 2 13,#3,5,2,4 LOW. MONITORED PIDS WHILE DRIVING. BOOST LOW AND VGT% STICKS AT 15% AND 85% FUEL PRESSURE INTERMITENT LOW, WORN REGULATOR, EGR VALVE COKED. REMOVEDD BOTH VALVE COVERS AND REPLACED #3,5,2,4 INJS REASSEMBLED. REPLACED TURBO, EGR VALVE AND FUEL PRESSURE
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 33 1A02 030008 3C3Z 6051 CA D50 D8 43172
AWS Claim Key: 13767736 Trx Code: E72 Labor Hrs: 14.5
Dlr Cd-Sub Cd: 09217 - * Name: APPLE VALLEY FORD LINCOLN MERCURY Ph: 952-4315900 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:53357703
Cust Comments: CHECK FOR COOLANT LEAKING FROM OVERFLOW ADVISE....
Tech Comments: CCD8 6051 PRESSURE TESTED COOLING SYSTEM AND CHECKED FOR LEAKS, NONE FOUND. REMOVED EXHAUST TO CHECK FOR EGR COOLER LEAK, NONE FOUND. ADDED GAUGE TO COOLING SYSTEM AND TEST DROVE. REACHES 20PSI AND PURGES COOLANT, NEEDS HEAD GASKETS. DISASSEMBLED, CLEANED AND CHECKED HEADS AND BLOCK FOR WARP. REPLACED HEAD GASKETS AND REASSEMNBLED. CHARGED A C AND
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 33 2H01 030008 3C3Z 6K854 DA E41 D8 43172
AWS Claim Key: 13767735 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09217 - * Name: APPLE VALLEY FORD LINCOLN MERCURY Ph: 952-4315900 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:01-MAY-2006 Doc #:53357707
Cust Comments: CUST WAS IN 05 03 06 AND ADDED THERE IS AN EXHAUST LEAK
Tech Comments: CCD8 6K854 REMOVED TURBO AND REPLACED EXHAUST ADAPTER, REASSEMBLED. PAID TURBO R&R ON LINE #1
1FTSW31P13ED63399 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-JUN-2003 12-SEP-2003 158594 USA 33 2H01 030008 * 6K682 * D50 82 44083
AWS Claim Key: 13957241 Trx Code: S07 Labor Hrs: 0
Dlr Cd-Sub Cd: 09217 - * Name: APPLE VALLEY FORD LINCOLN MERCURY Ph: 952-4315900 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2006 Doc #:53955101
Cust Comments: CUSTOMER SEEKING REIMBURSMENT 200.00 ON DEDUCTIBLES AND 1 VEHICLE PAYMENT KRISTEN.ABDO INVOLVED
Tech Comments: SEEKING REFUND
It has been 2 times since this last posting..
Elk
Colorado
It really sucks red. I don't know what else to say... :(
Northeast Texas
WOW
you know that bucking in a sharp turn...there was a wiring recall to fix that,
but man you have had some run of luck
Maxtor
Redding
:eek: :eek: :eek:
I would get rid of that truck in a heartbeat. You can not trust it. If you went on a long trip, you would be worrying all the time about a breakdown.
So far, my truck has been flawless. No problems. If I were you, I would trade that one in on a new 07 PSD. With all the problems that the 2003 60 engines have had, I would not be to quick to purchase a new 6.4 engine.
BTW... My local high performance Diesel garage guru told me that he has had more Ford 6.0 engine problems than all the other diesels combined. He mostly sites the 10 head bolts and the egt system causing the most problems. He recommends no power adders for the 6.0 until after 30,000 miles to make sure that you have one of the good engines. I would think, that by now, the 2007 6.0 engines are about as good as they are going to get.
Good luck...
Ford should buy back your truck.
Maxtor
Kleetus
Butler PA
Yeah, I agree... I would have parked that thing at the dealership with a giant lemon on the side. I know you need it as a work machine, but for as often as it's been in the shop, you haven't been able to do much work with it....
WOW, your fingers must be tired after that looooooooooooonnnnnnnnnggggggg post. :roflmao
didnt know you could type that good red. ;)
:sorry
i gotta call lemon on this one too red. i hope things work out for ya bud! :sweet
powerstrokeguy
Weatherford, Tx
man that is impressive! i would definately agree that is a lemon! i think u should really work on gettin rid of it. you dont have to live with that. i think you should try for an 07, that may be your best bet. or hold out for the 6.4. sorry for all your problems. i hope everything gets better for ya.
TacoCat
