Intercooler separating OEM
Oboy
Belen, NM
I figured out why I’m not making boost, and this is why,
Is this common? Any reason why is would happen?
Which after market to look at.
Thanks Mark
NO not comon, that I know of. Over boost would do it or a bad clamp job from the maker. Over boost will show the weak spot in the system, whats was your boost running before. Take it to a rad. shop and have them take it a part and clean it and reclamp it. They need to replace the rubber O ring seal on the tank.
Oboy
Belen, NM
Good idea! Do you think they will be able to get the o-rings?
Mark
Should, it's a big rad. basely. Should be able too. Would not hurt to try.
Oboy
Belen, NM
Update, I found one at a salvage yard cheep, went over to pick it up and it is doing the same thing as my old one. At the same location, it was starting to separate. So I went and ordered an after market intercooler. I just hope this will permanently fix this issue.
Thanks for all the help!
Mark
KRISTOLSON
Thief River Falls, MN
I would be worried about overboost conditions if thats the case. A little overboost won't hurt but I think if its enough to seperate the intercooler, and you know its not just a freak event with one flawed intercooler, you are looking at a LOT of overboost. You might prevent some serious engine damage by taking a little time to look over the turbo.
Oboy
Belen, NM
I got the new Mishimoto Intercool in and looks sweet!
Fit like a glove. Nice install.
Got it installed and the truck seems to be more responsive and runs like champ! Very HAPPY!!! ;tu
Next upgrade will be the coolant filter.
Thanks to all who replied!
Mark
Ricksofla
