Question Injectors
JRJ04
Houston, TX
get on the freeway and take it out of OD and go about 70mph. thatll put you right around 3k rpm...run it there for a while and that should clear you out pretty good.
A question for you guys...when you change the glowplugs, do you have to clear the cylinders out too or is there no oil that get in that area?
Glow plugs will not cause oil or ANY other fluid to enter the cylinders, so nothing is needed for the glow plug change.
iracemine
black and tan
Cheese Curtain
Well just got my injectors changed out. Chn=anged glow plugs and valve cover gaskets as well. Took a bit to getter going but it finally fired up. Wow teh power I noticed was unreal. Probably put 20 miles on around my home, easy and gettin on it. Parked it for the night plugged in of course. Below zero here in hte northwoods of WI. Next day fires up ok, take for a ride and notice that at RPMs of 1700 or less it runs ruff as hell. Next day took on road trip to Green Bay figures it would clear out but nothing doing. At 50 mph, 1500 rpms, the steering wheel is like to shake out my hands. Anybody had anything like this happen? Thanks for reading.:dunno:confused:
rotate your tires. start there for the steering wheel shimmy, it prob packed snow.
iracemine
black and tan
Cheese Curtain
Some people don't have a clue do they!!!!:dizzy
oh, sorry its hard to read your writing. you said your steering wheel was shaking bad at 50 mph. had no idea that you meant it was from your motor. next time use proper english and ill be able to help you out better. ;tu
JRJ04
Houston, TX
:innocent
There are a lot of people here that don't/won't use proper English. I just ignore those posts. No help here.
Jaxn76
Rhinelander, WI
I did in fact say the steering wheel was shaking that badly. But I also said I had just changed the injectors. I certainly didn't do that outside in the snow.
