Question Injection Replacement
roger2003
Milwaukee,WI
I was just given the news on my smoking/ studdering/ lack of power, I have injector on number 4 cylinder that is falling flat on idle and under load plus another injector on same side. I,m going to replace all four on that side of the engine but my question is this a project that a shade tree gear head can handle or should it be left to the professionals? I am all about wrenching on my own truck but, to quote a famous actor " a man has got to know his limitations". Any help on procedure would be helpful. Thanks.:dizzy
You had better get the "book" on your truck before you make that decision. I am the same way about doing my own wrenching, but not on this truck. Experience means a LOT. Look at how the injectors are put into the heads and what all is involved just getting to the injectors and then make your own decision. Good Luck!
scottu5
