Injection pressure regulator
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Where is the ipr on a 06 6.0? My truck still has the no start when warm problem. Took it back to the dealer and since it doesn't throw a code or won't do it for them they will not put any parts on it to see if that fixes the issue. I am willing to either rebuild or replace things to make it right. I'm still under warranty but that hasn't helped when they don't do anything.
DR.Diesel
marlow ok
They need to do a air pressure test on the high pressure system.they can turn the ipr off with a scanner and listen for air leaks.usually when it starts cold and hard/wont start hot you have a leak in the system somewhere.usually its the stc fitting or the dummy plug o-rings on the high pressure oil rail.the lower seal blows out causeing the lose of oil pressure in the oil rail.there have also been cases of a sticking ipr valve and possible a low pressure oil pump regulator valve sticking in its bore on the front pump housing.but id bet on the hiogh pressure system leak.just my thought.
scottu5
