Income Tax Money, Help Me spend it!!
97shortcrew
Hello all, this is my first post here although i have been reading these forums for a while. I have had my 1993 cummins for about 5 years now and have just recently purchased a 1997 crew cab Shortbed 5 speed for the way better room it has. :thumbs Now my delima is that i dont know much about bombing a powerstroke:dunno Athough i am right at home working and upgrading a 12v cummins.:D I have about 1400 dollars to spend. So fill me in as to a few good worthwhile mods. Truck is stock with 140k miles except for gauges. so lay it on me guys
Wade
Welcome to the site..
twildman programmed chip, Tymar intake, 3" Downpipe, Straight 4" exhaust and a set of injectors should just about take care of that $1400.
97shortcrew
what kind of egt heat would i be looking at with that? Because I run to college rodeos quite a bit grossing about 16000# . Thanx guys
If you use some good chip programming with a set of stage ones from Bean or a set of Baby Swamps, egt's will not be a problem.
Welcome to the site Wade. First, you are going to find out that the 7.3 PSD isnt as easy to bomb as a 12V. Thats just the facts. But, they are very bombable <---- is that a word?
Crumm has you pretty well covered in the performance dept. Do the exhaust and intake first then move on to the chip. If thats not enough for you, injectors are a good investment especially since you have 140K on your current squirters. A set of Stg I's are under $700.00 I think. When you are towing, just keep an eye on your EGT's, keep them under 1250/1300 degrees, keep your RPM's up, this is a V-8 and it likes boost and RPM's, both will keep your EGT's in check.
97shortcrew
WHere would be the best priced and good customer service to get the tymar intake and twildman chip i cant seem to find anything as to where to get it. sorry i'm a newbie to the Stroker world
Tbar
SDD STAFF/Moderator
Can't help ya. Mine is always leaving my wallet............not returning. :confused: :confused: :confused:
Tbar
lukecline
Kansas
You can get ahold of Wildman at totaldieselperformance.com or 405-818-6365. Beansdieselperformance.com can set ya up with an intake and exhaust.
Luke
97shortcrew
twildman programmed chip, Tymar intake, 3" Downpipe, Straight 4" exhaust , with all of this what will be my approx. power level?
Luke
And 'jectors if you choose to go that route.:thumbs Ryan Bean is a great guy to talk to. Drop by his website and give him a phone call, its worth your time.
