Eubee
Finally got around to working more on my F250. Here is where I stand with it now:
-Truck is still a crank no start.
-ICP replaced, reads 550PSI during cranking
-Fuel pressure manually read at ~47PSI during cranking (from test port on secondary fuel filter housing)
-Oil level is good
-HPOP shows no physical damage
-IPR proven to be properly operative by applying shop air to oil log and applying battery voltage to IPR
-High pressure oil system does not leak when shop air is applied to oil log and IPR is closed
-IPR did have some debris on screen, but not enough to block oil flow
-Being that the injectors are in parallel (and therefore not in series) with each other on the oil logs, I do not feel that a bad injector could 'block' oil flow in the system. If I am wrong in my thinking here, please help me understand.
Dealer claimed that the truck was not building enough oil pressure to start engine. They claimed the HPOP would probably need replaced. If the High Pressure Oil System is operating properly; is it possible for the HPOP to build proper pressure even if base engine oil pressure is too low?
Thanks for any help.
FWIW: I agree that it is way easier to work on that engine with the cab off!
-Oil level is good
