ILL RUNNING STROKER HELP!!!!!!!!!!!!!!!!
HOTROD32
MY POWER STROKE IS NOT RUNNING WELL I PULL THE CODES . THEY ARE
O470,P1211,P1249,P1316 . THE DISCRIPTION OF P1316 INJECTOR DRIVER
DOES NOT SOUND GOOD . DOES ANYBODY HAVE ANY IDEAS????
IT IS A 2000 F350 4X4
Don't type in all CAPS. It is YELLING and we all get too much of that. It is very hard to read also. I don't know too much about 2000 Power Strokes. My DVD's are for 6.0 liters.
Alexandria, Virginia
Okay so we have:
P0470 Exhaust Pressure Sensor Malfunction
P1211 Injector Control Pressure Sensor Above / Below Desired
P1249 Wastegate Control Valve Performance
P1316 Injector Circuit / IDM Codes Detected
Now just because you throw a code - does not mean there is an actual problem with an item - due to the fact that another part can affect the readings for others.
So - looking at your list - the first thing that I would start with would be what's number one on the list - the Exhaust Pressure sensor. Not because it's listed first - but if this goes bad or out of whack - it will affect the others causing them to give bad readings.
Tell us more about what's been happening and/or mods that you may have. Ever remove the ICP connector? Seal gone - corroded terminals etc - this could also cause all of these codes.
Next question is - are you still under warranty?
Ron
Yeah,
Can we get a little more clarification on what "not running well" means? Is it missing at idle? Low on power? Lotsa smoke? or flat out not running?
HOTROD32
sounds like injectors on rh side ,loss of power,could it be the harness?????
BigRamrod
