idle problem
Tates97
Tate s97
Madison Ga
MY IPR was bad. I cleaned it but it did'nt fix it until I put a new one in. I would start it and exactly 10 seconds later it would run a couple hundred rpms the settle down. Tate
GREG
i pulled the fuel filter housing and the harness going to the ipr was trashed so i fix it did not fix problem but i have not every had the a ipr off so do you just take the nut loose and screw it and clean it thanks for help
GREG
i pulled the ipr off the truck and cleaned it i took it apart and cleaned it still the same deal did not change anything thanks
GREG
well i fixed my truck i the pcm reflashed by jodi now it is great
Jriltex
