I think I murdered my truck, HELP!! PLEASE
early 99 stroker
White Mt's NH
i did the same thing to my 99 in the fuse pannel under the hood there is a large green 30A fuse..cant remember where it was....but it was blown out..replaced it and she fired right up...use a test light..turn key on and test both sides of the fuses..
johnsonkcng
pueblo west, co
you were right
Everyone kept saying fuses, and I swear I thought I checked that one with a light, I took it out and looked at it and it looked fine.I guess I was focused under the dash. After thinking about it over the weekend I decided to start over, using the advise I got from you guy's. Sorry I doubted you. The 30 amp under the hood was bad. This fuse doesn't look like the others, you cant tell its bad by looking at it. Does it have to be replaced with the same type or will any 30 amp maxi be ok? Thanks again for the help. Great forum.
Thanks
Ken
Thanks
Ken
if you're asking whether to use Littlefuse or Bussman, it really doesn't matter..
but it has to be a 30A Maxi..
