Hush Mat Question
Keller, TX
Thanks, Don, and everyone else!:thanks
Door seal mod has already been done. I wish every mod was as easy as that one. :D
i used CLEAR poly/vinyl tubing...1/4ID-3/8OD, it was 20cents a foot
at lowes, its reported that youll need 55ft to do a crew cab...
i bought 60+ feet.
i used a FISH TAPE to push a nylon string thru the hole in
the weather strip. (having pulled the weather strip off the
channel around each door)
i thread the string thru the LARGE opening in the weather strip.
then i poked a hole thru the poly/vinyl tubing...then i tied
the string thru the hole in the vinyl tubing...then i pulled the
string BACK thru the weather strip...w/ the vinyl tube tied to
the string the vinyl tube will follow as you pull the string....
keep some soap/water on the vinyl tube as you pull it thru and
it will glide thru w/ a little bit of effort.
re-install the weather strip and shut the door...hard.
jhamlin164
San Clemente
BUSH MADE A BELIEVER OUT OF ME................
Hi Guys,
I put some the Hushmat (cheaper than Dynamat) stuff in my truck...............WOW! :D Man this stuff is great..........you take a Kenwood Satellite radio, 2 JL Audio amps, JL Audio 5X7s and a Stealth Box sub and put it all into a King Ranch crewcab and it's SHEER PANDAMONIUM! :D
You will not regret putting this stuff in your truck! It takes sound quality to another level.
Regards,
Jerry
platinum01
Willis, TX
Bush I guess I need to get some so that we can put it on my truck. Need to do the roof and at least the back of the cab. Stacks make it kind of loud. But when you are cruising it is not so bad.
its a hell of a difference thats all i can say...if you wanna see the material
(i have some left...still wanna pull the seats and do my floor...but need help ;)
youre always welcome to go for a ride or drive mine to see how
quiet it is.
platinum01
Willis, TX
Door seal mod is awsome. Makes the cab air tight. Have 4 10's behind the back seat and with then cranked and the mirrors viberating about to come off you still can't hear it outside. Bush I'll have to make my way down there and check your ride out. Need to just go and buy some dynamat and install it.
