bserventi
My ESOF will not engage the 4x4. I have traced all the vacuum lines and isolated the the problem to the drivers side hub. From what I've searched it seems like the hub seal is what needs to be replaced.
What is the correct part number of this seal? Is it a easy fix or are special tools required?
Are there other seals or O rings that need to be replaced while I am installing this new seal?
Thanks
Thanks
