my wonderful wife got me the HPX from Tymar and I put it in today with apparent success. Some tight squeezin' but it's in. Dale's instructions are good but could use some side notes. As he suggested I took off my orange turbo boot but getting that sucker back on was a time consuming challenge. I finally figured out to put it on the turbo first and then onto that metal thing coming from the air intake. The other thing I noticed, the instructions suggest, if necessary, to loosen the supply hose from the HPOP in order to maneuver that line to connect to port #4. I didnt need to but noticed later that if you loosen it, you can rotate the 90* fitting up a little and take some stress off the line. No big deal and I dont intend to go back and do it now but might be a good idea.
Anyone else do this on the 7.3? Only thing I noticed that made me nervous - I placed rags under the ports to catch any oil leak while working but noticed when I was done there was a semi-large oil puddle on the ground below. Probably 2 -3 cups worth of oil. With rags in place I cant figure out how that much oil could have run down. I'll watch it to make sure that was the source but suspect it must have been. If you've done this, did you experience the same thing?
Have a good new year everyone. I've been offline for almost a week so Im a little behind.
