hpop oil leak
kodiak
virginia beach, virginia
have oil leakin into valley pretty sure hpop o-rings runs a little slugush intermitently question: will changing o-rings be enough or is hpop gone too?
Y2KW57
USA
Try the orings first. It is common for the orings to leak without there being a fault with the hpop itself.
ProXJC
Michigan
I had the plug go bad on the hpop and it leaked pretty bad. Like a quart every five minutes. I had to replace the hpop and I still get oil in the valley, but its pry two quarts every 3000 miles.
