hpop lines(new guy)
bigfred
fog city/ca/usa
seems like mine is leaking from were it connects to the hpop box bought a set of o-rings from deiselorings.com and i think they show you how to make a special tool i guess to remove the line anybody know or replace the o-ring with just regular tool like a line wrench,thanks
bigfred
fog city/ca/usa
so its not tread its press on.so just pop off using a pry tool & to reinstall just push or press it back in ?
IHC Power
STOCK STROKE
Walpole Mass
HPOP Lines
The style line International uses on that engine have a plastic retainer on the top of the barbed end and on the inside they have 2 locking tabs, when you pull the plastic retainer up the line will then have to be pushed down to release the lock, then pull up to disconnect... I used a leatherman and a pair of round needle nose pliars to get r done, JL has a good method also.;tu
FlorWhitfe
