How to Turn Off Daytime Running Lights
snicklas
Super Moderator
Staff member
Greenfield, Indiana
Not sure on the newer trucks, but on the 97 and older trucks there was a "module" that plugs in the wiring harness behind the switch, on those, remove the plugs from the module and plug them into each other, rather than the module, and DRL is gone.... back to standard US Headlights...... that plug is on all the trucks, just the ones with DRL have the module.
Maybe something the same on the 99+ Superduties.......
frankmako
Tennessee
i found out how to do it. there is a resistor module infront of the driver side battery next to the headlight. it is under a wire mesh cover/box. unplug the wire and no more daytime running lights. the auto lights still work and all is good.
W4RLR
High Tech Hillbilly
Sewanee, TN
I'm in the process of moving to Tennessee, and I WANT daytime running lights. Right now I get them by covering up the sensor for the auto lamps. Would like to have the DRL module, though.
Stroked68
This is FORD Country
Eudora, KS
My gf's truck had the daytime headlight feature. We hated it. Just removed the fuse and no more.
