May 3, 2011 #1 bears4x4 grease monkey Joined May 20, 2007 Messages 709 Reaction score 1 Location katy texas How do I remove the hpop on the 7.3, I have heads, hpop and turbo lower housing left
May 4, 2011 #2 M majek5 Full Access Member Joined Sep 23, 2009 Messages 133 Reaction score 0 Location Northern Il http://www.dieselsite.com/pdffiles/adrenalineinstallationinstructions.pdf
May 5, 2011 #3 D dieseltech1 SDD Junior Member Joined May 5, 2011 Messages 18 Reaction score 0 Location tampa fl you have two high pressure oil lines that take a special tool or just unscrew fittings two studs or bolts then pull access cover off of front houseing there is a bolt remove that and the gear is a wedge fit
May 5, 2011 #4 bears4x4 grease monkey Joined May 20, 2007 Messages 709 Reaction score 1 Location katy texas thanks yall
May 5, 2011 #5 JLDickmon ursus combibo Joined Jun 22, 2006 Messages 4,173 Reaction score 12 Location 49041 the special tool ain't that special... I've done it with a GM fuel filter tool...
