How much horsepower is needed to get an 02 250 in the 14's
onefastt
Mississippi
02 4x4 extra cab 7.3. Can 14's be achieved with a ts performance 6 pos chip set on 140 horse setting and a turbonetics turbo? If not what is needed to achieve a 14 second quarter mile?
CSIPSD
Bend, OR
Without intake and exhaust? I'm betting around 15.6-16... Even with everything, your going to be high 14's
01SMOKINSD
Wakeman, ohio
Hey guys, newbie here. I have been to the track many times and run consistant 15.90's with my programer on the 110 HP setting. I haven't run it since I shimmed the FPR to see if that made much if any difference. I would have to say that 14's are very possible with an aftermarket turbo and a good high HP chip. Just my .02 worth. By the way great site!:burnit
CSIPSD
Bend, OR
FPR shim will do 0 fro HP at the track...
Your running Hi 15's, it takes alot to drop A full second at the track...
85 psi... be careful, you should carry a spare fuel pump...
onefastt
Mississippi
So you believe with an intake and exhaust this setup will get into the 14's? He's also thinking of putting on the gtp-38r
CSIPSD
Bend, OR
With a good chip, a well tuned truck, and a tight tranny, you should see 14.9-15.5....
lukecline
Kansas
stage 2 injectors and custom tuning will get you low 14's with the right supporting mods
FlorWhitfe
