How many miles on your stock 4R100?
How many miles on your stock 4R100 Transmission?
  • 0 to 50,000 miles
    Votes: 4 6.9%
  • 50,000 to 75,000
    Votes: 5 8.6%
  • 75,000 to 100,000
    Votes: 2 3.4%
  • 100,000 to 150,000
    Votes: 22 37.9%
  • 150,000 to 200,000
    Votes: 16 27.6%
  • over 200,000 miles!
    Votes: 6 10.3%
  • Forget stock,I went with a BTS!!
    Votes: 3 5.2%
  • Total voters
    58
Scooter
Mesa, Arizona
Our Excurison lasted 54k until it decided it was not longer part of this world. It had never pulled a trailer at the time.
My 2000 pu has 188k on it right now, and it pulls a 8500 lb. trailer 90% of the time.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Factory one crapped at about 165K of towing a 8K trailer.
Now have about 115K on my BTS.
JRJ04
Houston, TX
107000 and I thought it was starting to go because I had a lot of flaring between 3 and 4, but after I got rid of the superchip, I realized it was the chip doing it. When I return it to stock, I can put it to the floor and it will shift right through every gear with no problem. Now that I have the predator, it shifts a whole lot better and I cant say that I've really hammered it to see if it slips but........I will tomorrow just to let you know!:sly
Tbar
SDD STAFF/Moderator
I have had a similar experience.
Mine also improved significantly after I installed the Sonnax/Tricumulator. I wonder how often a new kit should be put in?
Tbar
Tbar
I think the sonnax tricumulator kit is a permanent fixture but the fluid/filter needs to be changed every 25-30k if running dino fluid. Changed yours lately T?
Tbar
SDD STAFF/Moderator
I will have to look. Changed mine the same day you did.........at a mod day. I am using synthetic.
Tbar
fire245man
fire245man
Harrodsburg, KY
266k and had 18,000lbs behind it every friday. was an early 99 with marbles in the TC. sounded like hell but ran like a champ! changed fluid every 20k
blueoneton
Baltimore, MD
I have 63,600 on my 2002 F350 my stock 4R100. So far so good, however I have had the trans flush/filter changed prior to every 30,000 miles. I have thought about synthetic fluid but the trans shop I deal with stated it would be a good choice if I tow/pull alot, which I don't.
patrickc
Ontario, Canada
My bone stock 4R100 let go at 155K miles second gear started to slip. New one has 85K miles of abuse and still going strong.
