W4RLR
High Tech Hillbilly
Hello all,
I've had the ScanGauge II installed for a couple of weeks now. It's great to actually have working gauges as opposed to the glorified idiot lights that are the factory gauges.
Here is my question. I am told that anything over a 15 degree difference between oil temperature and water temperature is bad juju. But I get up to a 30 degree difference depending upon terrain and loading. I had a 35 degree difference climbing the I-24 Monteagle 6 % grade Monday. Once I got back on the flats on the other side, the temperature difference went down, but only to a 20 degree difference.
I did have the cooling system flushed with a machine last year, and added a DieselSite coolant filter, but I am thinking I may have the beginnings of a clogged oil cooler. Would a run of RESTORE and RESTORE PLUS be a worthwhile first effort to possibly clean a silica clog in the oil cooler fins? Is this something so bad that I should not drive the truck?
Looking forward to your sage advice.
