Hopping when i hit the brakes.
onefastt
Mississippi
There is a bad wobble when i hit the brakes. Its so bad that it will almost shake you out of the seat. It sounds like the driver side wheel is bouncing when i apply the brakes. I have replaced the shocks. there is a clunk in the front end when i go over bumps. Its driveing me nuts. Also the drivers side front looks lower than the passenger side.
2001 Crew Cab 4x4 7.3 diesel swb
silverado3500
Wiltshire, United Kingdom
First off, I susupect that your wobble/shake is most likely warped rotor. As far as your clunk goes, I'd start by checking your ball joints, and wheel (hub) bearings.
Wood County Tx
is it lifted
miles on tie rods
miles on tires
u-bolts on axles spring perches
miles on brake pads?
air pressure in tires?
condition of tires?
warped rotors will cause a pulse in the pedal and a shaky sterring wheel ,but worn tie rods, overinflated tires, worn out tires will help to cause shake and shimmy wobble that may bounce you around
more info would be :sweet
any of these working together could result in said wobbly gobblinism
RickGmi
Southeast MI
I remember
I remember reading something about that,, you might want to check TSB and stuff....might want to have someone watch your tire and brake slowly to see if you have control arm play...tire will move back and forth as brakes are applied
All of the above along with worn shocks can make it lots of fun to drive.-mad let us know what you had to do to get it fixed. Good luck.:sweet :sweet
Brad1103
