Holy moley turbo/compressor surge!
rammertide07
Rogersvilles, AL
Wow, great info guys. Thanks to all!
Ok so, with the all talk about the CPS, which one is better? Grey? Black?
Also..where's this sensor located? (in case I *do* get gutsy and attempt to replace it myself)
No guts needed...
lay underneath the truck, looking between the engine and radiator with your feet toward the rear of a truck. Its on the passenger side of the engine. Just unsnap the plug and use a ratchet (size?) to undo the bolt holding it in. Pull it out and put the new one in...reverse the process. Check out the wiki articles at the top right of this screen..select the categories icon then your model. CPS replacement instructions are in there if I remember correctly.
mike.germann
Lexington Park/MD
Awesome. Doesn't sound TOO hard. I'll see if I can get over to Ford to check it out.
Or at least hit up the website to check the recalls.
