RazzyB
Mad Scientist
Was surprised, after removing the (factory?) plastic bedrails to see ~20 holes in each rail. I'm gonna have a spray-in bedliner installed, what do most people do with the rails? Put the factory caps back on?
ibsmurf said:I left the factory caps on and just had the liner sprayed only inside the box....
jvencius said:Same here...
RazzyB said:So, I should reuse or replace the oem bed rails caps...does anyone know if they can be replaced with black as opposed to gray?
thanks!
jvencius said:IIRC, they only came in one color.
