Hipothetical Question
bendog
Medford Or.
So if..........06E17 removed the exhaust back pressure sensor from the PCM strategy, could I remove the EBP and install the thermocouple for a exhaust gas temp gauge? It is in the driver side exhaust manifold.........:rolleyes: Any thoughts?
bigdiesel99
corinth texas
I think you can if you get the connector plug from SP diesel so the EBP sensor does not set a code, adn if you have the correct thread adapter for the manifold.-popcorn
bendog
Medford Or.
I was told that 06E17 eliminated the ebp from the PCM strategy......so if it has truly been eliminated you should be able to remove and discard it. Question is, is that a good location for the egt sensor and can I get an adapter to thread it in, if it does work, I dont have to drill (remove) the manifold. I will try unplugging the EBP and see if it throws any codes.
no-red 6 0
Senioritis
southmetro MN
i want to do the exact same thing. had been told no need to drill because i could use that spot. need more info. anyone??
TacoCat
