High Pressure Oil Readings
roosterdiesel
Earl needs B100
Amarillo,TX
I installed a HPOP gauge to do some troubleshooting.
At very light throttle(3rd gear @ 30mph) I get a surging sometimes almost bucking. Been told to check the IPR. Well during the explained situation, the HPOP is dropping and rising about 400-500psi. Also at cruising speed on the highway there is about a 200-300psi fluctuation. When I have a cold start in my Tow program, the truck romps pretty hard a few times. The gauge is spiking to close to 3000psi and dropping off to almost nothing. Doesn't do it in the other programs. :dunno
This sounds like the IPR sticking right? I have the rebulild kit but don't want to fix what isn't broken.
JimmyDee
God Bless America
Western Michigan
I think you are correct. I have monitored and recorded my HPOP in all different situations and there is fluctuation because of increased or decreased fuel demands but at a steady demand it stays fairly constant. Idle pressure is about 550-600 psi and I have seen as much as 3200psi under full throttle. This was without a chip or programmer.
Jim
roosterdiesel
Earl needs B100
Amarillo,TX
JimmyDee said:
I have monitored and recorded my HPOP in all different situations...
I wish I had EASE or Autoenginuity. :( Good thing we've got some lonely roads around here, watching the gauge on the cowl wasn't that easy. :eek:
Brad1103
