High Idle Mod Question
This question is for an Excursion
I went out to do the High Idle Mod which uses the Ford provided PTO Control for the PCM to raise the idle to 1200 RPM.
I went looking for the wire, #322 from the above procedure. Looking at the 2003 Body Builder Layout book, page 199 there should be a total of 8 Customer Pass-Through wires above the parking brake area. One of which is my needed 322 Light Blue / Yellow Stripe wire for the PTO Control.
I see all the other listed wires in that bundle, except wire 322. Has anyone else done the High Idle mod on an 2003 Excursion 6.0? Or, did Ford leave that option out on the Excursion, thinking it would never need a PTO or the associated controls?
