ecm already has the built in high idle programs...up fitter switches will work if you tap the correct wires in the upfitter link
and.......
l
the big difference in the 6.0 and the 6.7 seic strategy is HEAT management, which i am sure like mentioned previously has everything to do with the emissions setup to prevent excessive under body heat.
like to see a new truck getting modified already
