High EGT's
dmd
Member
Double Oak, TX
When installing this filter what do you do with the air sensor and the filter restriction guage that are both mounted on stock air box?:dunno
Most just add it to their tool boxes. You can also drill a hole in the top
of the filter plastic and put it there.. I found a site once that a person
put up with how they did it.
I do normal street driving and plan to replace it around 15k.
dmd
Member
Double Oak, TX
You will also hear surge if you have it... Need an ATS housing or WW to cure that...
Brad1103
