Hi Beam + Lo Beam mod really works!
W4RLR
High Tech Hillbilly
Sewanee, TN
Wood County Tx
bama-six-gun said:
ok, what does TDS mean? man at all the abbrevs you gotta learn around here. hehehehe:roflmao :roflmao
THE DRAMA STOP, THE DUMB SH&&s, THE DARK SIDE, TURKEYS DANCING STRANGELY
:D
or my favorite
team roper dimes you OUT -mad
Keller, TX
It's actually The Diesel Stop, Stephen. Good site for some information gathering (if you can read between the BS), but I don't participate. The ego's and bitching are unbelievable on that site! I'm very happy here.:D It's where I post my questions, knowing I will get honest, straight forward answers.
X-Hibition
Idaho
The high beam low beam mod can actually be enhanced in this fashion for maximum reliability.
I have used the APC wiring loom, but I wasn't impressed with the relays (not true, I thought they were junk). So when one failed I replaced both with continuous duty solenoids (they look like the old Ford starter solenoid...don't use them!) requiring you to cut off the molded plugs from the APC kit and use solderless connections. The connections are obvious, I can elaborate if need be.
The sweet part was thinking about the Painless kit for Chevy trucks to illuminate high and low beams and realizing a simple diode would make it happen. So with both continuous duty solenoids mounted above each other I connected the solenoids with the diode inserted and all four headlights were on, or in this situation it would be both filaments in a single bulb.
The continuous duty solenoids are hell for tough as they are used for switches in golf carts (36 volts) and as Chrysler glow plug relays. You must use ones that are rated for continuous use, and I can't think of a system you could protect with them that would ever fail. Plus you can use tiny trigger wires to activate and huge wires to your accessory.
ah, 'scuse me... fella's?
is this an off-road only mod?
If I remember right, federal law limits you to 55watts...
