help!!!!
tz07uli
dublin,ca
ok guys, I own 07 6.0 f-250 and i'm a little bit :confused:,I'm trying to replace my oem air filter.
After long research i've dicided to go with the afe replacement filter.
According to afe it supposed to be a direct fitting, that means to take out the paper filter from the housing box and to install the afe filter in the same box.
well... Apparantly it's not working because the filter comes as ONE with the box,(acording to ford from 03-07) and all the venders that sell this filter don't
sell replacement box with it. :rant
Has anyone done this replacement - and where do you get this replacement box?
Help is appreciated!
F350DRW1
Waylon Fan
N.J.
The instructions should mention cutting the OEM filter element out of the box. Thats how "Green " filters says its done. I would imagine the AFE works the same way. Good time to do zoo-dad while your in there.
tz07uli
dublin,ca
oem filter
I found the instructions on airaid .com,thank's for the info ;tu
I guess afe forgot to mention this small (BIG) dteail:dunno
