Shraderman
- Joined
- Aug 8, 2005
- Messages
- 33
- Reaction score
- 0
A thought?
I think Budro and T-Bar are right on the tire issue. I've had that many times. It's a slipped or broken belt and you can actually feel it if you run your hand around the surface of the tire. It'll make the whole thing do a hula at a certain speed, but can appear normal at another speed. I tried balancing them as well, but if it's a broken or slipped belt, balancing won't help.
Just a thought on your oil, you said that it was cold when it was misbehaving. Could the Penzoil somehow be not working well with the high pressure oil pump? I'm no mechanic, but based on other posts, it sounds logical (eg symptoms the same).
Just food for thought
Richard
Richard
