Help, Took HFCM apart, parts fell out
walter.dreyer
Flashover
OFallon Mo.
and I don't know how they go back together. I have a 2003 6.0, I took the fuel water separator cover off to change the drain plug since it is stripped. I have a black plastic piece that seems to fit in the upper compartment. I also have a plastic valve with springs, and another valve I believe to be brass? Where do these parts go.
maybe call the dealer parts dept and see if they have an exploded view?
walter.dreyer
Flashover
OFallon Mo.
Dave, what I really need is a blow up of the return valve. The dealership mechanic said it is broken, that's why it came out in pieces. The problem is I don't see anything broken, I'm not sure I have all the pieces, and I can't figure out how to put the valve back together
You got what is on the DVD. This DVD does not show every detail that you might need. Sorry I can't be of more help...
Dave:dunno
scottu5
